First build please help
This is my first build just put some stuff together please help. And is this all compatible?
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
Case: http://www.newegg.com/Product/Prod [...] 6811119233
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
HDD: http://www.newegg.com/Product/Prod [...] 6822152185
CORSAIR Builder Series CMPSU-600CX 600W ATX12V v2.3 Active PFC Power Supply
PSU: http://www.newegg.com/Product/Prod [...] 6817139019
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBPK
RAM: http://www.newegg.com/Product/Prod [...] 6820231179
GIGABYTE GV-R567D3-1GI Radeon HD 5670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
Graphix card: http://www.newegg.com/Product/Prod [...] 6814125360
ASUS 24X Burner Black SATA Model DRW-24B3LT LightScribe Support - OEM
DVD: http://www.newegg.com/Product/Prod [...] 6827135221
GA-MA78LMT-S2 AM3 760G mATX AMD Motherboard
MOBO: http://www.microcenter.com/single_ [...] id=0350746
AMD Phenom™ II X4 840 3.2GHZ quad core
Processor: http://www.microcenter.com/single_ [...] id=0357031
6 answers Last reply
More about first build help
  1. All compatible, looks good.
    Your links are dead BTW.
    Uhh I'm assuming you are referring to these deals here. In which case you should take some extra money and put it towards the 965. The 8xx are rebranded Athlon II X4's to sound legit for the OEM makers. In reality they fail in comparison to the actual Phenoms.
    http://www.microcenter.com/specials/promotions/AMDbundlePROMO.html
    810 vs 965 (in essence the perf. difference)
    http://www.anandtech.com/bench/Product/82?vs=102
    Better PSU - 60$ after promo, 40$ AR. Plus it's modular and 80+
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
    Out of stock but my usual rec.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
  2. We need more info before we can say.
    Budget?
    What are you going to use this for?
    What resolution monitor?
    And please fix your links.
    Budget?
    Budget=$500ish
    Mostly be playing WoW
    And probly a 1080p tv
  4. Then the 5670 is inadequate, probably something like a 460 768mb or a 6850 would work better.
  5. Subtotal:484$ After Rebates
    http://www.tomshardware.com/reviews/best-gaming-cpu-core-i3-2100-phenom-ii-x6-1075t,2859-3.html
    http://www.tomshardware.com/reviews/best-gaming-cpu-core-i3-2100-phenom-ii-x6-1075t,2859-10.html
    ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
    19$
    Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
    40$
    Total 543$ After Rebates
  6. Can you afford a 880G mobo?
New Build Systems Product
