Power Supply for GeForce 460 SLI
I'm planning on running the 1gb 460 in SLI, would this power supply be sufficient
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171052
2 answers Last reply
More about power supply geforce
  1. That might struggle, go higher. Perhaps a SLi-certified 800w if you're overclocking or a good 750w if you're not.
  2. If you won't overclock, it will be enough. If you will overclock, I would recommend a 750-800W or more PSU.
Graphics Cards Power Supplies SLI Geforce Graphics Product
