Closed Solved
Will this PSU be compatible with tri-fire 6970s?
i will have 3 6970s and the maximus iv extreme MOBO
will the CORSAIR Professional Series AX1200 1200W ATX12V v2.31 / EPS12V v2.92 SLI Certified 80 PLUS GOLD Certified Modular Active PFC Power Supply work with 3 6970s
link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014&cm_re=1200w_power_supply_80-_-17-139-014-_-Product
is 1200w to much (i plan on an OC to 4-4.5GHz on SB)
if it is should i go for 1000W
thanks :D :) :D :D :D
i will have eyefinity so please don't tell me to go for the 580s instead because i really need the 2GB vram
4 answers Last reply Best Answer
More about will compatible fire 6970s
Graphics Cards Power Supplies Compatibility Graphics Product
