Solved
Building new amd system need some help.
Here are the items that i do have and i will explane what i want out of this.
Case-Silverstone raven rv01 with ap181 fan upgrade:)
Psu- Kingwin 850 gold
Gpu- gtx 580
Cooler- h50 or v10
Hard drives- 4x 1tb seagates and a 40gb ssd ocz
Drivers-dvdr blur ray
What i want to get is a Amd cpu,mobo, and ram
I want those 3 things to work perfectly/flawlessly with what i have and with each other. I wan the cpu,mobo,ram to overclock very high and be stable and make it a easy overclock. i am sick of things not working correctly together so i need all of your help. If there is anything eles you need to know in order to help me please let me know.
Computer will be used for games like bc2,guild wars, and diablo 3:)
5 answers Last reply Best Answer
More about building system help
  1. Hi there, here are my suggestions, what is your budget for the 3 parts?
    AMD Phenom II X6 1100t
    Gigabyte GA-890FXA UD5
    Corsair Vengeance 4Gb 2X2
    Cheers
  2. Two questions:
    1) What is your budget.
    2) Are you willing to consider Intel?
  3. For games going for Intel Sandy Bridge is better
  4. Best answer
    I'm with sr26 get an I5 2500k the new boards come with easy overclocking and they absolutely smash the amd chip sets when comes to gaming. I have an overclocked I5 2500k stable @ 5.0 ghz.
  5. Best answer selected by cia24.
New Build Systems
