Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > [Solved] Motherboard Sound Cards
Forum Motherboards & Memory : Motherboards [Solved] Motherboard Sound Cards
Best answer from inzone.
Hello.
Do motherboards that are up to $150 usually have 7.1 surround sound built in?
Thanks.
Message edited by Storm Slider on 02-09-2012 at 05:03:24 AM
Reply to Storm Slider
A lot of motherboards now have 8.1 channel surround sound at most prices and the higher the price the more the features like THX , Dolby Digital and Crative EAX.
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$121.99
http://www.newegg.com/Product/Prod [...] 6813157271
As an example this motherboard has these features;
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), Supports THX TruStudio
Reply to inzone
Best answer
MSI Z68MA-ED55 (B3) LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$139.99
http://www.newegg.com/Product/Prod [...] 6813130596
This one has ;
THX TruStudio PRO: deliver the fullest audio experience
GIGABYTE G1.Assassin LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 XL ATX Intel Motherboard
$339.99 and a $80 rebate
http://www.newegg.com/Product/Prod [...] 6813128472
Then you have a motherboard like this one;
Onboard Creative Soundblaster X-Fi Digital Audio Processor (20K2) with X-Fi Xtreme Fidelity and EAX AHD 5.0 Technologies
Dolby Digital Live
DTS Connect
Built-in Front Audio Headphone Amplifier
Nichicon High-end Audio Capacitors
These features are built into the motherboard and it almost makes a seperate sound card not nesscesary. There will still be some people that just like to have a seperate sound card.
Reply to inzone
What really matters is that you get something with optical output, and put good money into your receiver, speakers, and headphones. Even 'cheap' $100 mobos put out better quality audio than your average speaker system.
Also, remember that God gave you 2 ears not 7, and 2 speakers that cost the same as a 7.1 channel system will sound infinitely better. A properly set up stereo will sound just as 3D as having 100 speakers (granted it is harder to find a room that can manage it acoustically).
Reply to CaedenV
A good quality pair of headphones is a great option and you don't disturb anybody else if you are cranking up the volume. I used to think that you had to have a killer set of speakers to take advantage of the sound on the MB , untill I got a pair of V-Moda headphones.
http://www.amazon.com/V-MODA-True- [...] 41&sr=8-15
Reply to inzone
$139.99
This one has ;
Dolby Digital Live
DTS Connect
Does that MSI have 7.1 surround sound?
Yes it says it has 8 channels and to my knowledge 8 channels is 7.1.
Reply to inzone
Oh. So I won't be needing to spend $30.00 on a 7.1 Surround sound sound card. Thanks.
Your welcome.
You do however always have the option to put in a sound card if you want to but I haven't used a sound card for a long time now.
Reply to inzone
I thought at first that motherboards had bad sound cards or like a normal 5.1 sound, but knowing most have 7.1 surround these days you don't quite need a sound card.
Oh, and uhm, I would appreaciate it guys if I could get some replies from this thread I made:
http://www.tomshardware.com/forum/ [...] w=0&nojs=0
This topic has been closed by Nikorr
Reply to Nikorr
There are 1835 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in installed RAM, computer properties
By smorizio, 1 hour ago:
windows 32 bit has a 4 gig limit and with parts on the bios shadowing some of the ram...
Best offers
Top experts
