Does this build work
Hey all just wondering weather my new build fits together well and if theres anything better i should change to. All reply's will help.
Intend to use www.pccasegear.com as im from Australia
Note i havn't chosen: Case, Monitor, Burner.
CPU: Intel Core i5 2500K ($269.00) - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&sessionid=81a7cbc8872714ec3bbc874304207b69&keyword=Intel+Core+i5+2500K
MotherBoard: ($209) ASRock P67 Extreme4 Motherboard B3 - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=ASRock+P67+Extreme4+Motherboard+B3
:($235) ASUS P8P67 PRO Motherboard B3 - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=ASUS+P8P67+PRO+Motherboard+B3
GPUz: ($339.00) XFX Radeon HD6950 2GB - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=XFX+Radeon+HD6950+2GB
: ($279.00) Galaxy GeForce GTX 560Ti 1024MB - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Galaxy+GeForce+GTX+560Ti+1024MB
: ($209.00) XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity - http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
HardDrive:($99) Western Digital Caviar Black 1TB WD1002FAEX - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Western+Digital+Caviar+Black+1TB+WD1002FAEX
: ($69) Samsung SpinPoint F3 1TB HD103SJ - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Samsung+SpinPoint+F3+1TB+HD103SJ
PSU: ($149.00) Antec TruePower 750W Blue - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Antec+TruePower+TP-750+750W
: ($149.00) Silverstone Strider Plus 750W ST75F-P - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Silverstone+Strider+Plus+750W+ST75F-P
CPU cooler: ($33) CoolerMaster Hyper 212+ CPU Cooler - http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23_845&products_id=12544
RAM: ($84) G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBSR - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417&cm_re=g.skill_sniper-_-20-231-417-_-Product
: ($105) G.Skill Ripjaws XL F3-10666CL9D-8GBXL (2x4GB) DDR3 - http://www.pccasegear.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=G.Skill+Ripjaws+XL+F3-10666CL9D-8GBXL+%282x4GB%29+DDR3
Cheers
2 answers Last reply
More about does build work
  1. Yes it is all compatible.
    I don't think the WD 1TB FEAX is worth ~$30 over the Samsung Spinpoint, as in all the tests I've seen the Samsung is typically faster, quieter and cooler than the WD.
    I think the Silverstone edges the Antec because of longer cables, fully modular and higher efficiency.
  2. As someone who owns a setup with 5850 in crossfire I don't know if I'd buy one of those at this time for a new build. Staying with the current generation of cards, even if technically less powerful, will give you better tesselation support and measureably better crossfire/SLI scalability.
    Don't get me wrong: I'm extremely happy with my setup now that it's more or less working, but I would stick with current gen if building from new.
New Build Systems
