Solved
Difference between an audio jack adapter and a sound card?
What is the difference between an audio jack adapter and a sound card?
5 answers Last reply Best Answer
More about difference audio jack adapter sound card
  1. Best answer
  2. Thank you!!!
  3. jltrone said:
    Thank you!!!
    You are welcome! In Chicago, the answer you will most likely get is "The difference between an audio jack and a sound card is about $100" :)
  4. Best answer selected by jltrone.
  5. Thank you!
Sound Cards Audio Components Product
