Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > NEW BUILD please help
Forum Systems : New Build NEW BUILD please help
Here is my cart http://www.tigerdirect.com/cgi-bin [...] ,%201,%201
I am a first time builder. please help and let me know what you think. Thanks
copy and paste link
Message edited by jamn805 on 03-10-2011 at 05:49:37 AM
Reply to jamn805
You might want to post your list without using a link...
Reply to Selas
DESCRIPTION QTY AVAILABILITY SAVINGS TOTAL
C13-5700 ::Corsair CMZ4GX3M1A1600C9 Vengeance 4GB DDR3 RAM - PC12800, 1600MHz, 1x4096MB, Non-ECC, Unbuffered(0.9 lbs)
Order Today, Ships Today $109.98
($54.99 each)
$20.00 Mail-in Rebate
L12-1344 OEM ::HP HPDVD1260I Multiformat DVD Writer - DVD+R 24X, DVD-R 24X, DVD+RW 8X, DVD-RW 6X, DVD-RAM 12X, SATA (OEM)(1.95 lbs)
Order Today, Ships Today $19.99
C283-1202 ::Cooler Master Hyper N520 CPU Cooler - Socket LGA 775, AM2, AM2+, 1156, AM3, 1366(2.3 lbs)
Order Today, Ships Today $29.99
A406-1134 ::NZXT Sentry II SEN2-001 5.25" Touch Screen Fan Controller(0.75 lbs)
Order Today, Ships Today $34.99
M17-7302 ::Microsoft Windows 7 Home Premium 64BIT Operating System Software - OEM DVD, English(0.6 lbs)
Usually ships within 5 - 7 Days $99.99
TSD-500AS7 ::Seagate ST3500418AS Barracuda 7200.12 Hard Drive - 3.5", 7200 RPM, SATA 3G, 500GB, 16MB Cache (OEM)(0.95 lbs)
Order Today, Ships Today $39.99
E145-0475 ::EVGA 01G-P3-1366-TR GeForce GTX 460 SE Video Card - 1GB GDDR5, PCI-Express 2.0, Dual DVI, Mini HDMI 1.4, DirectX 11(2 lbs)
Order Today, Ships Today $159.99
C283-3058 ::Cooler Master RS750-ACAAE3-US GX Series 750W Power Supply - ATX, 750 Watts, 80+ Bronze Certified, SLI Ready, 120mm Fan(6.1 lbs)
Order Today, Ships Today $99.99
V18-2238 ::Viewsonic VX2250wm-LED 22" Widescreen LED Monitor - 1080p, 1920x1080, 16:9, 1000:1, 10000000:1 Dynamic, 5ms, DVI, VGA, Integrated Speakers(10.7 lbs)
Order Today, Ships Today Original Price:
Instant Savings:
Price: $199.99
- $50.00
$149.99
I69-2600K ::Intel Core i7-2600K BX80623I72600K Unlocked Processor - Quad Core, 8MB L3 Cache, 3.40 GHz, Socket H2 (LGA1155), Retail(0.5 lbs)
Order Today, Ships Today $329.99
A455-3035 ::ASUS P8P67 Pro B3 Intel P67 Motherboard - ATX, Socket H2 (LGA 1155), Intel P67 Express, 2200MHz DDR3 (O.C.), Gigabit LAN, 8-Channel Audio, SATA 6.0 Gb/s, SuperSpeed USB 3.0, SLI/CrossFireX, Bluetooth(3.8 lbs)
Usually Ships in 7 - 21 Days $189.99
C283-1187 ::Cooler Master HAF 932 Full Tower Black Case(34 lbs)
Order Today, Ships Today $139.99
Click to remove the item from your cart.
Enter Zip Code to Calculate Shipping & Tax:
(We only charge tax in FL, IL, NC, TX, GA, SD and ID)
SUBTOTAL
S&H Ground (3 to 7 days)..$16.16Truck (3 to 9 days)...$63.93Second Day (2 days)...$68.64Next Day.............$110.19
TAX ----------
TOTAL
You Saved $50.00 Today!
Check out now before these deals expire!
Reply to jamn805
my bad....just copy and paste.... will fix thanks for pionting out
Reply to jamn805
hey its michael get the antec true power 650w same price but better
Reply to mjmjpfaff
also go with a gtx 460 not se. se is a downgraded version of a gtx 460. or go with a 560 ti. a sparkle 560 ti is on there for 229.99 with rebate. but if u are going to get something along the price of 160 try looking for a 6850. overall it is better than the gtx 460
6850- http://www.tigerdirect.com/applica [...] CatId=3669
get this one
Reply to mjmjpfaff
http://www.amazon.com/Western-Digi [...] 384&sr=8-7
i got this one but the next one i will post is still as good. you want a 32 mb or higher cache if u want better speed
http://www.amazon.com/Western-Digi [...] 384&sr=8-1
Reply to mjmjpfaff
Is that cpu cooler better than the 212 plus?
Reply to jamn805
also insteasd of that hp get an asus dvd burner for the same price:
http://www.tigerdirect.com/applica [...] CatId=1624
or this sony
http://www.tigerdirect.com/applica [...] 0&csid=_21
either one is better than that hp
Reply to mjmjpfaff
whats ur new total do u have speakers and keyboard/mouse. ethernet cable for it or r u goin wireless. power surge protector etc.
Reply to mjmjpfaff
fully enclosed already oc'd a little more than that aus 6850. i think it has better cooling and only 5$ more
Reply to mjmjpfaff
heres what i mean about a 6950 1gb
http://www.tigerdirect.com/applica [...] CatId=7005
here are some benchmarks
http://www.guru3d.com/article/rade [...] -review/11
-the older games go to the 6950 since it is just a little bit older than the 560 ti. also at higher resolutions the 6950 wins. at war games however they are neck and neck but the gtx 560 usually comes on top. (except for crysis warhead)-crysis 2 will go to the gtx 560 ti
Reply to mjmjpfaff
M501-1186 ::Sabrent CRW-UINB 7-Slot USB 2.0 Internal Memory Card Reader & Writer - Aluminum, SDHC/SDXC/M2, USB 2.0, Black, 3.5", Self Powered, SDHC, MicroSD Support(1 lbs)
Order Today, Ships Today $9.99
P33-6110 ::Patriot PGV38G1333ELK Gaming i5 8GB PC10666 RAM - DDR3, 1333MHz, 2x4096MB, 9-9-9-24(0.1 lbs)
Order Today, Ships Today $89.99
C13-2502 ::Corsair TX650W 650-Watt Power Supply - ATX, 120mm Fan, SLI-Ready, SATA-Ready, 80Plus(6.45 lbs)
Order Today, Ships Today $87.99
TSD-500AALX ::Western Digital WD5002AALX Caviar Black Hard Drive - 500GB, 3.5", SATA 6Gbps, 7200 RPM, 32MB(1.8 lbs)
Order Today, Ships Today $54.99
M452-6209 ::MSI P67A-GD65 B3 Intel P67 Motherboard - ATX, Socket H2 (LGA1155), Intel P67 Express, DDR3 2133MHz (O.C.), SATA 6.0 Gb/s, Gigabit LAN, CrossFire/SLI Ready, USB 3.0(4.05 lbs)
Usually ships within 3 - 5 Days $189.99
A455-5022 ::Asus DRW-24B1ST 24X Internal DVD Burner - DVD±R 24X, DVD+RW 8X, DVD-RW 6X, DVD±R (DL) 12X, DVD-RAM 12X, CD-R 48X, CD-RW 32X, SATA, 2MB, Black, OEM(1.8 lbs)
T925-1293 ::Thermaltake V9 Black Edition Blk Mid-Tower Case VJ400G1N2Z - ATX, mATX(18.1 lbs)
Order Today, Ships Today $94.99
C283-2054 ::Cooler Master RR-B10-212P-GP Hyper 212 Plus CPU Cooler - 120mm, LGA 1366, 1156, 775, AMD AM3, AM2+, AM2(2 lbs)
SUBTOTAL
S&H Enter a Zip Code
TAX ----------
TOTAL
$1233.38-40 mail in rebate+keboard, mouse, vertex 2, monitor, (sound card??)
Reply to mjmjpfaff
AMAZON
Shopping Cart Items--To Buy Now Price: Qty:
Item added on March 11, 2011
Thermaltake VJ400G1N2Z V9 Black Edition Mid Tower Marvelous Gaming Case with 23cm Silent Fan - Thermaltake USA Direct
Condition: New
In Stock
Eligible for FREE Super Saver Shipping
This will be a Gift (Learn more) $89.99
You Save:
$30.00 (25%)
Corsair CMPSU-650TX 650-Watt TX Series 80 Plus Certified Power Supply - Corsair
Condition: New
In Stock
This will be a Gift (Learn more) $89.73
You Save:
$19.26 (18%)
Windows 7 Home Premium 64 Bit System Builder 1pk - Microsoft Software; DVD-ROM
Condition: New
In Stock
You Save:
$39.01 (30%)
Intel Core i5-2500K Processor with 6 MB Cache, 3.30 GHz for Socket LGA1155 - Unlocked Boxed - Intel
Condition: New
In Stock
Shipped from: A Cichlid King
$221.89
You Save:
$20.54 (8%)
Cooler Master RR-B10-212P-G1 Hyper 212 Plus 775/1156/1366/AMD/AM2/AM3 Universal Direct Contact Heat-Pipe 120mm Fan CPU Cooler - Cooler Master USA, Inc.
Condition: New
In Stock
$26.41
You Save:
$3.58 (12%)
NZXT SENTRY 2 Accessories 5.25-Inch Touch Screen Fan Controller (Black) - iBuyPower
Condition: New
In Stock
This will be a Gift (Learn more) $24.99
You Save:
$5.00 (17%)
Patriot Memory Sector 5 G Series 8 GB (2x4 GB) DDR3 PC3-10666 1333 MHz 9-9-9-24 Dual Channel PGV38G1333ELK - Patriot Memory (Direct)
Condition: New
In Stock
This will be a Gift (Learn more) $84.99
You Save:
$22.00 (21%)
tiger direct total-283.70
amazon total-633.98
total=917.68-20 mir=897.68+ your last order + mouse and sound card
txt me ur total
Reply to mjmjpfaff
at frys there is a samsusng spinpoint f3 7200 rpm 32mb cache and 1tb for only 50 bucks
Reply to mjmjpfaff
SUBTOTAL
S&H EconoShip (4 to 9 days)..$5.74Ground (3 to 7 days)...$8.47Second Day (2 days)...$15.10Next Day..............$26.71
TAX ----------
TOTAL 225.71$
http://www.newegg.com/Product/Prod [...] 6811129021 -cheaper by a dollar and sturdier
Condition: New
In Stock
You Save:
$19.26 (18%)
Condition: New
In Stock
You Save:
$39.01 (30%)
Condition: New
In Stock
$221.89
You Save:
$20.54 (8%)
Condition: New
In Stock
$29.99
Condition: New
In Stock
$24.99
Condition: New
In Stock
$84.99
+sound card, mouse, and hard drive at frys
Reply to mjmjpfaff
http://www.tigerdirect.com/applica [...] =G452-0126
thought i could save a few bucks on mobo.......still does Sli so what the heck. rite?
Reply to jamn805
http://www.tigerdirect.com/applica [...] CatId=2533
What about this one power supply......semi modular, only$69
Reply to jamn805
its a good one. at newegg its 120 dollars
Reply to mjmjpfaff
people say its a stable (msi) mobo.........whats the news with yours???? any news
Reply to jamn805
hey what about this dude.....
this one:
Item #: E145-0463
COMPARE EVGA 01G-P3-1371-TR GeForce GTX 460 Video Card - 1024MB GDDR5, PCI-Express 2.0, Dual DVI, Mini HDMI, SLI, DirectX 11, Fermi
NVIDIA delivers unheard of performance with the all new Fermi GPU and the GTX 460!
$169.99*
In Stock
Manufacturer: EVGA Avg. Rating:
or this one:
EVGA 01G-P3-1370-TR GeForce GTX 460 Video Card - 1024MB GDDR5, PCI-Express 2.0, Dual DVI, Mini HDMI, SLI, DirectX 11, Fermi
$169.99*
In Stock
Manufacturer: EVGA
Reply to jamn805
they are both more expensive and not as good as the 6850 if u want to go nvidia wait for the 550 ti to come out on march 15
Reply to mjmjpfaff
http://www.frys.com/product/603050 [...] IN_RSLT_PG
here is a very good case for 88 bucks in store dont mind the price on the website
an also the hard drive at frys is 5400 rpms dont get it look for another one
Reply to mjmjpfaff
mjmjpfaff wrote :
heres a 5850 better than any 6850 or gtx 460 u can get-
http://www.amazon.com/DisplayPort- [...] 573&sr=1-3
A sapphire HD 5850 can be bought off newegg for $139.00 here is the link:
http://www.newegg.com/Product/Prod [...] -_-Product
Reply to mlCaouette
There are 1760 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1200-1400 Gaming PC - Want Opinions
By Why_Me, 1 hour ago:
The Z68 boards are older and targeted for Sandy Bridge cpu's. For the newer Ivy Bridge...
Best offers
Top experts
