Online help for sound card with pci port connectivity 5 1 of headphone
Tinku_01
Hello, i have used creative 5.1 external sound card. but give in card working properly. sound is too low of sound card. i want use my cabinet's front port are working for headphone. plz help me
Welcome to Tom's Hardware Forum!
There are volume controls that need to be adjusted; one in the sound card, and one in the program that you are using.
If the sound level in the sound card control is set low, then regardless of how high you set the volume in the program you are using, the output will be low.
A good approach would be to set the sound card volume control to about 80% and then adjust the output volume by adjusting the volume in the program.
