Fighets and Laser Mines: Safe Speed?
Last response: in Video Games
Archived from groups: alt.games.vgaplanets4 (More info?)
I'm not sure, but there should be a safe speed. It is probably the
same for ships.
The reason that I'm replying though is to let you know that if the
minefield owner decides to detonate the laser minefield then all
fighters are vaporized. You may want to consider splitting up your
wings into small wings so you can minimize your loss and make the
detonation less appealing. Web minefields are the only other minefield
that I'm aware of that stops (not damages) wings.
Magik
Ask the community
