Hello everyone this is my first time building a computer in a long time so I would like some help please in some choices for parts and a opinion on some of my choices. Here is what I am looking at
ASUS P8P67 LE B3 Intel P67 Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7343083&CatId=6978
ASUS P8P67 Pro B3 Intel P67 Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7343079&CatId=6978
One of these motherboards. Could someone please explain the difference between the 2 for me?
NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.613846
ASUS ENGTX570DCII/2DIS/12 GeForce GTX 570 DirectCU II Video Card - 1280 MB, GDDR5, PCI-Express 2.0 (x16), Dual DVI-I, HDMI, Display Port, DirectX 11, Triple-Slot, SLI Ready, Overclocked
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7280370&CatId=3669
OCZ OCZSSD2-2AGTE120G Agility 2 Solid State Drive - 120GB, 2.5", SATA II
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6371300&CatId=5300
Ultra X3 ULT40311 1000-Watt Power Supply (im pretty sure i have this in my old build)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4267989&CatId=2535
Also i have 4 WD BLK 1 TB hard drives for Raid allready bought on sale.
Any advice or tips on the build would be appreciated
