Soooo..couple of days ago i did a little servicing on my pc cause i had a problem with my motherboard...before that my front jacks were working properly...i am using win 7 and the driver is High definition audio device...i connect my headphones to the jack and open control panel>sound,it says that no headphones are connected....but when i plug in on the behind jacks they work properly...i say that my headphones are connected properly.i also tried fix it and did a scan and it also says that my headphones are not connected but they are connected!!!!
.i tried with my ipod and my headphones work....is there a problem with the driver or my system or aanyother problem..
thanks
thanks
