Tom's Hardware > Forum > Digital Camera > Digital Camera General > Manual focusing problem
Forum Digital Camera : Digital Camera General - Manual focusing problem
Archived from groups: rec.photo.digital (More info?)
I have a Panasonic Lumix FZ15. It generally does a great job of
auto-focusing, but sometimes I need to use manual focus. I find that at
least half of my manually-focused pictures are not sharp, even though
the focus looks right on in the viewfinder using the focus-assist
feature. I can't figure it out. Has any one else noticed this problem
with their Panasonic digital?
Duke
Sponsored Links
In article <21098-42095695-499@storefull-3253.bay.webtv.net>,
Why would you want to manually focus if the autofocus works so well?
My Fuji S7000 has a focus/zoom ring which is virtually useless.
Reply to Anonymous
In article <anyone4tennis-B59769.11373110022005@newssv.kcn.ne.jp>,
anyone4tennis@hotmail.com says...
I think this is a common problem with ALL EVF cameras... you need to TRUST
the auto-focus, because the manual focus (usually) cant be done on a low
resolution EVF.
Larry Lynch
Mystic, Ct.
Reply to Larry
Because maybe one wants to focus at a plane that the autofocus doesn't
want to. If an object has an extended dimension parallel to the line of
sight, it may be hard to make the autofocus focus on just the plane you
want to properly share the available depth of field. That is the
reason, for macro photography I use a film camera and scan the print. I
can't afford a good digital SLR. My digicam, non SLR is fine for most
things, but not macro photography where I really want to control the
plane of best focus.
Reply to Anonymous
> resolution EVF.
I've only had my Panasonic FZ20 a short time, so I've only had one
significant attempt
at manual focusing. Still, the results were superb, all things considered.
I was watching
the Dolphin show in Chicago's Shedd Aquarium in the late evening. The
lighting is
quite poor, the sky was overcast, and the sun had set. I manually focused
on the
place where I expected the Dolphins to jump and used the high speed burst
mode.
While the pictures were still much too dark and noisy, the focus was pretty
much
right on. }:) Definitely a fun experiment.
Dan (Woj...) [dmaster](no space)[at](no space)[lucent](no space)[dot](no
space)[com]
"Johnny take a dive with your sister in the rain
Let her talk about the things you can't explain
To touch is to heal / To hurt is to steal
If you want to kiss the sky / Better learn how to kneel"
Reply to Anonymous
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
