New Desktop Build - HELP!!
Hey. I'm looking to build myself a desktop computer. I've been using my old xps m1530 laptop, but I'm on a design course at uni, and it just doesn't run the programmes I'm using properly (Adobe Suite, etc..)
I don't have the faintest idea where to even start.
My budget for the build is about 450 - 500 pounds, not including a monitor. It'll mainly be used for fairly intensive graphic design work, and maybe gaming, although that isn't a priority.
Could anyone suggest me some decent setups/ ideas to get me started?
Thanks, James
2 answers Last reply
More about desktop build help
  1. Hi there below is a build.
    Phenom II X2 555 $100
    Asus M4A87TD EVO $100
    4Gb DDR3 RAM (Any company will do.) $60
    Corsair VX550 PSU $90
    Coolermaster Elite 334 $60
    Radeon HD 5670 $80
    This should just fit into your budget, if you want to you can look for a Radeon HD 3870x2 for $90 which gives better performance than the 5670 according to the hierarcy chart.
    Cheers
  2. This was me UK sub 500 quid build off Ebuyer UK :P
Build Desktops Systems
