Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > Problem with my X58AUD3r rev 2
Forum Motherboards & Memory : Motherboards Problem with my X58AUD3r rev 2
blue screen of death on cold startup after bios update ( FA to FH ) x58aud3r rev 2
Reply to drmoh
A BSOD thankfully is different than a Post Failure**. In the BIOS Load Optimized Defaults, save and boot. If that fails then Clear CMOS (Button or Jumper method); see -> http://www.youtube.com/watch?v=rdHH9KrceR0
Now if both of those fail then boot off your Windows DVD, assuming Win 7, press F8 use Startup Repair -> http://windows.microsoft.com/en-US [...] -Windows-7 and if needed System Restore.
Once, hopefully, in Window you may have a mix-match BIOS to Windows -- e.g. BIOS SATA -> IDE <=> Windows Start -> 0; the correct choices are SATA -> IDE <=> Start -> 3 <or> SATA -> AHCI <=> Start -> 0; see -> http://support.microsoft.com/kb/922976 use 'Fix It' or manually match-up BIOS and the Registry.
**Often when updating the BIOS if you set SATA -> AHCI then updated the BIOS the setting changes to SATA -> IDE and you end up with a BSOD at startup.
Reply to jaquith
the older version FA was working fine and no BsOD
Reply to drmoh
There are 1856 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in installed RAM, computer properties
By smorizio, 1 hour ago:
windows 32 bit has a 4 gig limit and with parts on the bios shadowing some of the ram...
Best offers
Top experts
