Is this a good setup for my case' cooling system
  • Power Supplies
  • Cooling
  • Fan
  • Cases
  • Components
Last response: in Components
June 11, 2011 6:51:03 AM
http://www.flickr.com/photos/64004966@N08/5820147052/in...
this link will bring you to the cooling setup for my CM Storm Scout.
Blue means intake, red means exhaust.
the two 120mm intake fans on the side panels have an airflow of at least 74 cfm and same with the exhaust 120 fan on the rear(back).
on top, is a 140mm exhaust fan with an airflow of at least 60 cfm same with the the two 120 intake fans infront (one on top and on the bottom).
So is this setup the best way to put it. If anyone have a suggestion on what i should do to make make computer's cooling setup much better than what i did, please do so.
Thank you for your effort and time to answer my question.
More about : good setup case cooling system
a b ) Power supply
June 11, 2011 7:16:48 AM
looks pretty good
heat does rise and you have it exhausting from the top mainly
Personally in my experience I like a straight front intake to back exhaust
spread evenly throughout case
basically cool air from front exhausting straight out the top and bottom
of the back
I have read that the side intakes are controversial
some say they help
others say they dont
also there is the question of positive air vs negative air pressure
I like more exhaust fans than intake fans to create a negative air pressure
basically the case is sucking in air
but fan placement in a case is a matter of trial and error
what works good for one case/setup might work horrible in another system
what you have there looks like it should be pretty good
IF you have cooling problems consider adding exhaust in back and removing one intake
but only if there is a lack of cooling
a b ) Power supply
June 11, 2011 9:14:28 AM
Yes your set up should give you effective cooling, but its now down to trial and error for the fine tuning the only way you will find out is installing the components and have them running prime with hardware monitor running.
a c 154 ) Power supply
June 11, 2011 3:20:24 PM
You're good .... In at front side and out thru top rear is SOP (standard operating procedure) ...... with more fans blowing in than out you can be sure that dust won't be sucked in thru grilles , slots and cracks.
a b ) Power supply
June 11, 2011 6:08:10 PM
Hey lets start the negative vs postive air pressure argument
Dust is ALWAYS going to get in
effective filtration is the best defense
not positive air pressure
air needs to move OUT of the case
with positive air pressure (more intakes than exhaust) you
end up with "dead spots" in the case which can cause overheating
Just my humble opinion of course :)
I could be wrong.....
June 12, 2011 2:31:37 AM
Thanks for the quick reply everyone! What i did is exchange the top side fan on the top front fan. Since the front fan doesn't really push air alot and heat goes up, I considered having a slower/lower cfm fan on that side panel. Just a correction on my info, the front bottom fan is 140mm with at least 60 cfm, and i'm thinking of buying a better fan than that. Which should I replace? the on the the top fan (not top front fan), the one from the bottom front fan or both. Both have the same specification and I'm just wondering if that's a good idea.
a b ) Power supply
June 12, 2011 3:12:26 AM
well more cfm is usually good if the fans are quiet enough
if the budget allows for both then do both
but as i said I lean towards more exhaust power than intake power
which is sort of controversial in the computer forum world LOL
