I am almost to the point to start my new build, only thing left is to see if I'm gonna have enough power to run this baby without a glitch. The main knowledge I'm lacking is of Graphics cards, and that is the part that is leaving me uneasy about having enough power. I am going to list my important build specs that will pertain to this problem and I would appreciate if someone with the knowledge can tell me if my current power supply will do the job, even if I add more RAM and such.
*** Current PSU - Thermaltake W0319RU TR2 RX 850-Watt Modular Power Supply - 850W, 140mm Fan, ATX, Modular, 80 Plus Bronze - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6624658&CatId=2534 ***
OS - Windows 7 64-Bit
CPU - Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
GPU - EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
System HD: x4 Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136794
Storage: x2 HITACHI Deskstar 7K3000 HDS723020BLA642 (0f12115) 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" - http://www.newegg.com/Product/Product.aspx?Item=N82E16822145473
x1 Seagate Barracuda LP ST32000542AS 2TB 5900 RPM 32MB Cache SATA 3.0Gb/s 3.5" - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148413
MOTHERBOARD - GIGABYTE GA-P67A-UD5-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128479
RAID - Adaptec RAID 6805 2270100-R 6Gb/s SATA/SAS 8 internal ports w/ 512MB cache memory Controller Card, Single - http://www.newegg.com/Product/Product.aspx?Item=N82E16816103221
CASE - Antec LanBoy Air Blue - http://www.hardwaresecrets.com/article/Antec-LanBoy-Air-Case-Review/1099
FANS: Scythe DFS123812-3000 "ULTRA KAZE" 120 x 38 mm Case Fan (for CPU) - http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
COOLER MASTER R4-L2S-122B-GP 120mm 4 BLUE LED LED Case Fan - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
Rest of the Specs of build (if interested): http://pastebin.com/vy6hC0JX
