C0MMANDO Distinguished Nov 7, 2011 151 0 18,680 Feb 14, 2012 #1 Wheres the graphic card power supply on the asrock z68 extreme3 gen3?
Solution D Deleted member 217926 Feb 14, 2012 No. It's a low end, low power card. The PCI-E slot that the card plugs into provides enough power to run it.
D Deleted member 217926 Guest Feb 14, 2012 #2 Wait....what? The power supply plugs into the motherboard. Many graphics cards also require the power supply to plug into them. The power supply is not on the motherboard......... Upvote 0 Downvote
C0MMANDO Distinguished Nov 7, 2011 151 0 18,680 Feb 14, 2012 #3 i have this.. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127612 Upvote 0 Downvote
D Deleted member 217926 Guest Feb 14, 2012 #4 It gets it's power from the PCI-E slot. It does not need to plug into the power supply. Upvote 0 Downvote
C0MMANDO Distinguished Nov 7, 2011 151 0 18,680 Feb 14, 2012 #5 so i dont have to worry about power on the graphics card? Upvote 0 Downvote
D Deleted member 217926 Guest Feb 14, 2012 Solution #6 No. It's a low end, low power card. The PCI-E slot that the card plugs into provides enough power to run it. Upvote 0 Downvote Solution
C0MMANDO Distinguished Nov 7, 2011 151 0 18,680 Feb 14, 2012 #7 Best answer selected by C0MMANDO. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Feb 14, 2012 #8 This topic has been closed by Nikorr Upvote 0 Downvote
