Does my motherboard support DDR3 - 1600Mhz speed?
here is my info about the board
Number of Memory Slots
4×240pin
Memory Standard
DDR3 2000(O.C.) / 1333 / 1066
Maximum Memory Supported
16GB
Channel Supported
Dual Channel
does this mean i cant run ram that has a clock speed of 1666Mhz?
1 answer Last reply
More about does motherboard support ddr3 1600mhz speed
  1. It'll support 800,1066,1333 and all the way up to 2000mhz,
    including 1600, 1800 and any possible frequency you can imagine, you can run at a
    random number like 1487mhz by tweaking from BIOS if you want, what matters is UP TO 2000mhz.
Memory DDR3 Support Motherboards
