Approximate Purchase Date: 1 1/2 weeks
Budget Range: $800 ( doesn't have to be exact)
System Usage from Most to Least Important: Gaming
Parts Not Required: keyboard and mouse
Preferred Website(s) for Parts: Newegg.com
Parts Preferences: by brand or type
Overclocking: Maybe
SLI or Crossfire: Yes
Monitor Resolution: 1920 x 1080
Additional Comments: i will like this to be a reliable gaming pc.
LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Writer LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335 $24
Athena Power CA-601YW80 Yellow SECC 1.0mm Steel ATX Full Tower Computer Case V2.92 EPS 800W Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811192240 $140
SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908 $175
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor (Model: HDZ955FBGMBOX)
GIGABYTE AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI Micro ATX Motherboard (Model: GA-880GMA-UD2H)
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM 1600 (PC3 12800) Desktop Memory (Model: F3-12800CL9D-4GBRL)
Seagate Barracuda 7200.12 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive (Model: ST31000528AS) Combo
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.548058 $324
total $930
is this a good reliable gaming build that would last for some time. and how do i crossfire the video card
Overclocking: Maybe
total $930
