A adonis sagayca Distinguished Jun 15, 2011 1 0 18,510 Jun 15, 2011 #1 Hello, what can i do to fix the broken pin of processor, i ned help.
H hilltopmonk Distinguished May 26, 2011 258 0 18,860 Jun 15, 2011 #2 you are buggered... sorry for the harsh reality. chips need minimum resistance, fixing chips would cause increased resistance and the resistance levels are what causes chips to work. The only thing you can do is replace the chip. Ebay is your friend here. Good luck Upvote 0 Downvote
jsc Champion Jul 14, 2004 16,893 6 52,960 Jun 15, 2011 #3 You may be lucky. The broken pin may be a supply or ground pin or not used for any other reason. If you hven't, go ahead and try it. Upvote 0 Downvote
Aravind Aarumugam Distinguished May 11, 2011 32 0 18,530 Jun 16, 2011 #4 If it arrived to you at current state, u can claim for an replacement. But if you've bent it then a credit card is the way to go. Use it to straighten the pin, if near the four corners, if otherwise i guess you're outta luck Upvote 0 Downvote
