So soon i shall be building my new system and i cant stop deciding on what case i should buy . As i like in singapore prices here vary alot with brands. Im looking at the HAF932 Black ($245) , the CM 690 II ($190) , NZXT Phantom ($235)
Here is whats gonna be inside:
AMD Zambezi 6 Core (upcoming)
1TB Hardrive + 1 SSD
AX750 or Seasonic X760
Noctua C14 or XIgMATEK Aegir or somthing similar
1 6970 or 1 580 of some sort, im liking the AUSUS DCUII 6970
1 CD drive and 1 Fan Controller (if needed)
I really dont know if i should get a Full tower or Mid tower......
I want to overclock both my gpu and cpu, but not to the limit. also i havent fully decided if i want to run the choice of my GPU in SLI/CFX as i dont think i willl use that sort of power to its full potential
So with the above and pricing what would you choose
You can also check out this pricelist if your suggesting any other cases, but if its not on there STILL SUGGEST IT
http://assets.hardwarezone.com/pv_obj_cache/pv_obj_id_972FED35AC968C7992051FDEBF19BBC30D533E00/filename/cybermind-parts_50.pdf
Thanks,!
Thanks,!
