Recommending a decent sound card for surround gaming
Last response: in Components
June 17, 2011 12:40:28 AM
I play FPS games a lot(BFBC2). I also listen to quite a lot of music.
My speakers are from Logitech 5.1 surround.
Can anyone suggest any ideas to me?
Thanks
June 17, 2011 4:14:56 AM
What motherboard do you have, usually anymore most motherboards comes with 5.1 if not 7.1.
June 17, 2011 7:41:04 AM
Im currently using Asus Rampage 3 extreme. But 3 days ago, when i started up my computer after a re-build, there was a pop and some smoke came out of my case. After that, my sound system is just gone. so i assume I've fried my sound chip, thus wanting a new sound card.
June 17, 2011 9:23:46 AM
Wow. I'd check if the MB has a warranty. Using a partly fried board doesn't seem like good idea. It could hurt the rest of youur hardware as well. You don't know what else is fried and when the next malfunction will happen.
June 17, 2011 6:13:29 PM
Absolutely..................+1
a b 4 Gaming
June 17, 2011 6:56:56 PM
Yeah...mobo blew up, and you want to risk using it?
