I have just put together a new DAW using the Intel DZ68DB motherboard. I have installed a new M-Audio Delta 44 sound card in the PCI slot and have turned off all the on-board audio (even in the BIOS) but I cannot get any sound out of my Delta 44 at all.
Everything is recognizing the Delta 44 sound card and everything says that it is 'enabled' but I cannot get any sound.
Yes, my amp is turned on, speakers are connected, and the sound card was tested in another computer so I know that it works.
I have tried moving the sound card to another PCI slot and it still won't work.
Does anybody know if this motherboard actually works with the older PCI style audio card.
Everything else seems to work ok except I get no sound anywhere.
I'm close to pulling out what gray hair that I have left, so I really could use some help here.
