Hi I'm looking for a socket AM3+ motherboard for an AMD FX-6100. I will be getting a 560 Ti gpu.
Features I want:
Dual SLI
Overclocking capability
USB 3.0
If you can't recommend a specific board I would appreciate suggestions about brands /or which Northbridge etc. I could also use a recommendation on which manufacturers are more reliable.
Thanks!
Features I want:
Dual SLI
USB 3.0
Thanks!
