REDO in correct format... kindly suggested by WannaTurnUpTheHeat
I should note that I have never built a computer before, but I've read quite a bit about parts.
Approximate Purchase Date: within the next 1-2 weeks
Budget Range: $1700-$1900
System Usage from Most to Least Important: surfing the internet, watching movies, Folding@Home, gaming
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website for Parts: newegg.com
Country of Origin: USA
Parts Preferences: I would like to use an Intel CPU & Asus mobo with a 24" LCD and full tower case)
Overclocking: Maybe
SLI or Crossfire: Maybe SLi
Monitor Resolution:1920x1080
Additional Comments:
This place is AWESOME!
Parts list:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Sparkle Computer Corp GOLD CLASS SCC-850AF 850W ATX12V / EPS12V 80 PLUS GOLD Certified Modular Active, 0.99PF Typical PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817103054
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
ASUS P8P67 DELUXE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701
ARCTIC COOLING ACFZ13 92mm High Performance CPU Cooler for Intel and AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186039
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
Intel 510 Series (Elm Crest) SSDSC2MH120A2K5 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
Model #:SSDSC2MH120A2K5
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167042
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Overclocking: Maybe
Parts list:
