Solved
Do I use both the 16 + 10 pin connectors to power my 24 pin mobo with my seasoni
This is my first full system build. I have an Asus P8P67 Mobo with a 24 pin power connector. I purchased the X 750 as my PSU. The X750 motherboard cable has a 24 pin end for the mobo connection and the other end (psu end) is split into a 16 pin and a 10 pin. Which do I plug into the X750, the 16, the 10, or both?
3 answers Last reply Best Answer
More about connectors power mobo seasoni
  1. Best answer
    Both...I have the same PSU I use it with my AMD build
  2. Thanks. Now I can finish my build.
  3. Best answer selected by tjcage.
New Build Power Systems
