I have an old GTX 285 that I would like to install in another system. The only problem is the card artifacts like crazy. It was purchased through BFG tech (now out of business). Ive had to RMA the card once before in the past, but now its impossible since they are out of business.
Ive seen examples of people fixing artifacting problems by removing the heatsink/thermal paste and heating up the board with either a heatgun or an oven. Apparently solder leaks onto circuits it should not be touching creating connections where there should be none.
Now the card is by no means being used, so its not a problem if I ruin the card (obviously I dont want that ), but I figured since BFG is out of business and the card is just sitting around collecting dust I might as well try to fix it myself.
Has anyone done this and had any success? Can anyone provide alternatives to fixing the card myself? Thanks in advance
