I apologize for this noob question, but I did some searching here and I didn't find much.
I'm considering changing my network set up. And I will need to run a 75 foot cable to my xbox, and another to my PC on the other side of the house. I know that you can run cat6 under 300m and it will function, but I'm wondering if that extra distance will add latency to my signal. When I search tom's hardware most people just want to know about bandwith, but for gaming I'm more concerned about ping.
So will the extra distance add latency or slow my signal at all?
I'll be using cable like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812119191
My router is a D-Link DIR-615 if it matters.
Also, I plan on running the cable under the floor, which is the ceiling of my basement. Any basic things about this I should know? I searched for an article on here but didn't turn up much. Obviously stay away from electrical cables, but will running it next to a coaxial cable cause interference?
Thanks in advance.
Thanks in advance.
