Sign-in / Sign-up
Power Supply Suggestions for a fresh build
  • Power Supplies
  • Build
  • Components
Last response: in Components
June 19, 2011 4:15:40 PM
I've just ordered a new board and CPU off of Newegg (Z68 Gigabyte UD7 and a 2600k). This is going to be my 4th 2600k build so far. I'd just like some input on previous experience with certain brands of PSU's. The main company I'm looking to purchase is Seasonic. They have two great PSU' that's I'm trying to decide between. The X 760 and the X 850. I realize the 760 will be more than enough to power my complete rig, it just kind of bothers me running at load all the time. I'll be overclocking the CPU to around 5ghz. The GPU's I'm using are two EVGA 570 SSC's overclocked to 900mhz core. Any input on experiences with Seasonic or if anyone wants to convince me to use a different brand I'd appreciate it. Thanks!
More about : power supply suggestions fresh build
June 19, 2011 4:34:55 PM
Complete build is
2600k
Noctua NH-D14
GIGABYTE GA-Z68X-UD7-B3
EVGA 570 SSC
8 gigs of Vengeance 1866
Corsair 650d
m
l
a c 91 ) Power supply
June 19, 2011 5:49:44 PM
Should have gone with an i5 2500k (assuming this is a gaming build). Anyways, although the lovely Seasonic X-760 will be enough, the recommendation is to get hold of a 850+ watt PSU. Thus, get the Seasonic X-850.
Now there is no negatives to point out for any Seasonic PSU. May be a value war wherein the equally awesome Corsair AX 850 is available for lesser price.
m
l
June 20, 2011 12:32:29 AM
It's about a 10$ difference between the two. Think for 10$ I'd rather just go with the OEM.
m
l
a b ) Power supply
June 20, 2011 1:51:16 AM
I only use Seasonic PSUs.
If you're gonna SLI, then I guess I would go with the 850w.
m
l
a b ) Power supply
June 20, 2011 3:28:25 AM
If you can, return that 2600K for a 2500K and save $100. Claim it's defective or something.
m
l
June 20, 2011 4:00:46 AM
Why is everyone hating on the 2600k? It's not worse in any way compared to the 2500k. I don't care if it's more expensive. You get more potential.
m
l
June 20, 2011 5:13:43 AM
We here recommend the X4 955 BE over the X4 965 BE wherein difference is hardly 20$. Here it is 100$. The only two things the i7 2600k offers above the i5 2500k are HT and an extra 100 MHz on stock clock. HT is useless in games. And the extra 100 MHz counts to nothing. Both chips can attain similar overclock levels. So it is wise to save the extra 100$ or Invest in some other component. No one here hates the 2600k. We just believe it has a different purpose.
m
l
a b ) Power supply
June 21, 2011 1:16:44 PM
As mentioned above, games do not take advantage of HT. If that is the primary purpose of your PC, then you can save around $100 and simply buy the i5-2500k.
If I were to build a new PC now I would buy the i7-2600k, but that's because I will be using it to encode videos and there are programs that can take advantage of HT.
m
l
June 21, 2011 9:04:59 PM
Well, if you were looking to save money, there's always the non-modular Corsair TX850 V2 850W, but judging from your build, you, or your clients, have money to burn, so stick with the x850 Seasonic.
And this thread isn't about the 2600k vs 2500k, no matter how much your nerd instincts make you want to prove how right you are about everything.
m
l
a b ) Power supply
June 21, 2011 9:13:12 PM
A vote for the AX1200 ? It's not worse in any way compared to the 2500k. I don't care if it's more expensive. You get more potential.
"It's not worse in any way compared to the AX850. It doesn't matter it's more expensive. You get more potential."
:pt1cable:
m
l
June 28, 2011 4:20:16 PM
The AX1200 would be complete overkill. I don't think I'll ever Tri SLI. I figured I should put up a picture of the final build. I ended up going with a few different parts than originally planned.
http://imageshack.us/g/89/imag0124z.jpg/ If you guys are interested.
m
l
June 29, 2011 2:04:07 PM
Nice. What cpu cooler is that? And is that a fan for the ram? Never seen that before. How does that even mount?
m
l
July 6, 2011 6:02:46 AM
Cleaned up the wires inside and added the AirFlow Pro kit to my Dominator. The fan on the ram is the Fan that comes with the Dominator GT kit. The CPU cooler is the Zalman CNPS9900 MAX-R.
Uploaded with ImageShack.us
m
l
