My new project is an old Micron Mellennia with an upgraded MoBo and processor. The board is an Intel D850MV, which unfortunately does not support USB2. I did install an old USB2 PCI card I had laying around to get USB2, but would like also like to install a universal media card reader in one of the front 3.5" bays. The local shop only had ones that plugged into the MoBo's front panel connector, which is only USB1. I couldn't find any, but do they make internal readers that will plug into my USB2 PCI card's standard internal USB2 connector? Do they make USB2 PCI cards with the internal motherboard header type connector? I found a USB2 male to USB A male adapter cable http://www.amazon.com/Adapter-designed-motherboard-external-connector/dp/B000V6WD8A/ref=sr_1_5?ie=UTF8&s=electronics&qid=1300542382&sr=1-5. Will this work?.
