ATI Mobility Radeon 4830 or ATI Mobility Radeon 5470 + 512mb dedicated
If hypothetically the cards were in the exact same machine,
Would the 512mb dedicated make up for the 5470 being a worse graphics card or not?
Any help would be appreciated, thanks (:
3 answers Last reply
More about mobility radeon 4830 mobility radeon 5470 512mb dedicated
  1. The strength of the GPU is much more important than the memory installed. You can check on them here http://www.notebookcheck.net/Computer-Games-on-Laptop-Graphic-Cards.13849.0.html
    The HD4830 is stronger than the HD5470 regardless of memory size.
  2. Thanks for the reply (: I used that website to check out both of them, but neither seemed to specify the dedicated memory, so I couldn't tell if it made a difference.
  3. The 4830 is going to give you better performance than the 5470, regardless of memory.
Radeon Mobility Radeon Graphics Cards ATI Graphics
