G
Guest
Guest
Hello, (PLEASE, read the whole thing; sorry it's long)
I'm buying a GT 220 and I live in Dubai so I can't buy online; only common cards can be found in computer shops;
any ways I am 14 years old just FYI and all I have now is 300 AED which is about $80 US dollars.
I have and extremely outdated PC- pre-built HP desktop with Pentium D 925 and 2.5 GB of DDR2 Ram (400MHz)
I have a 300w power supply with 19 amps on the 12v rail and a spare no-brand 450w with 16 amps on the 12v rail. My current graphics card is a 7300 LE 64MB (You can laugh now)
AND it's damaged by overheating, blue-screening me when I stress it although the temps are now low as I have better A\C at room temp of about 23 degrees Celsius.
Anyways I borrowed another card from a friend and it worked fine which confirms that I have a problem with mine and it's... 64MB!!!
I want to be able to play newer (or the latest) games at low or minimum settings.
I don't really mind if I can't play all games cuz I have a PS3, but I want to do 3-D animation in blender and video editing too and stuff- (Please answer sensibly- read this whole thing; on another website I was recommended a QUADRO 6000 lol, that wouldblow up my computer and my wallet, another guy recommended GTX 580s in SLI lol.)
After deciding that the GT 220 is the best card that fits my budget of $50 up to $80 which is all I have. ( The 9600GT is better but the 59w version that runs on a 300w PSU is so RARE, and I live in the UAE; hard to find computer components )
OK now getting to the main point on the NVIDIA website the GT 220 requires 300w.
The EVGA version requires 300w.
The ASUS version requires 300w.
The Palit version requires 300w.
and the XFX version requires 350w and it also happens to be the only version I could find in the UAE.
SO will it run on the my 300w PSU
Does XFX increase the recommended power buy 50w for safety or just to be on the safe side because most of it's cards require extra 50w OR do the XFX versions really require more power than the others.
If I can't power it than could I do something crazy like use 2 PSUs t the same time; buy jump-starting
one of them and using it to power the CPU, hard drive, DVD drive and
the other one or the main one which is the 300w currently installed to power the Motherboard
with only the 24-pin. (The other PSU will External... ok that is dumb but it works)
