Memory speed problem (yes I verified voltage)
Model Name : GA-M61PME-S2P(rev. 1.0)
M/B Rev : 1.0
BIOS Ver : f7a
VGA Brand : Nvidia Model : 6800GT
CPU Brand : AMD Model : AMD Athlon 64 X2 Dual Core Speed : 3.2 ghz
Operation System : Win 7 64-bit SP :
Memory Brand : Crucial Type : DDRII
Memory Size : 4GB Speed : 1066mhz
Power Supply : 400 W
I installed Crucial 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model CT2KIT25664AA1067 onto my motherboard (specs match up on voltage, 1.8) and I'm still getting downgraded RAM speed of 800mhz per the motherboard. This motherboard has no voltage adjustment and my max setting is 800mhz with this RAM installed. Is there anything else I'm over looking or doing wrong? Thanks a ton!
2 answers Last reply
More about memory speed problem verified voltage
  1. try higher cpu ratio ~
    It doesn't look like I can, my chip is locked and this motherboard has limited tweaking capability.
Gigabyte Memory Motherboards
