Strange PC Problem - Continuous fast & short beeps
Last response: in CPUs
- Motherboard Boot Problem...Continuous Short Beeps - Forum
- Continues Short Beeps when power up the PC HELP!! - Forum
- 1 long beep, 2 short beeps (continuous) with extra videocard. - Forum
- Short Continuous Beeps then 3 Beeps - Forum
- New Build - No Post - Continuous Short Beeps - Need Help Desperately - Forum
- New PC build problem, continuous beeping sound and no signal to monitor. Forum
- SolvedFailed machine - One short, then three fast beeps - Not sure which component is failed. Forum
- MB good until waking from sleep continuous short beeps Forum
- Continuous Short beeps, restart, one beep Forum
- SolvedAsus P7P55D wont POST - 1 long beep, 0-3 short fast beeps Forum
- SolvedGigabyte Motherboard RAM Channel broken? - gives continuous short beeping when any RAM is inserted into Channel A Forum
- Continuous, short, and very loud beeps... Forum
- SolvedWhen my PC boots up there is a beep code( 1 long , many short beeps) and then restart. Forum
- Short Continuous Beeps Forum
- Continuous short beeps on GA-P55M-UD2 Forum
- SolvedProblem with my old toshiba laptop - Infinite short beeps at login. Forum
- Continuous short beeps with no display Forum
- Continuous Short Beeps on Boot, doesn't into OS Forum
- SolvedContinuous short beep on GA-X58A-UD3R with i7 930 and 6GB Kingston Forum
- hi, there is a problem when i start my pc it beeps continuously untill i do not press any key or it starts properly...after o Forum
- More resources
Yes, it could be the CPU as well (maybe the motherboard and CPU). The only way to actually find out would be to use a different motherboard or use a different Processor.
