Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > ? Laptop is running constantly at maximum speed
Forum Laptops & Notebooks : General Laptops & Notebooks - ? Laptop is running constantly at maximum speed
Archived from groups: comp.sys.laptops (More info?)
My laptop, Dell Inspiron 1150 2,800 MHZ is now running at it's maximum
speed after I rendered a home movie. Previously, my laptop's performance
would vary depending on load.
Does anyone know what has happened?
Thanks
Sponsored Links
I solved the problem on my own. Just want to share the fix. The
rendering s/w adjusted the power management settings. I went into
Control Panel > Power and changed it back to my previous settings.
Sneaking thing for the s/w to do without letting me know.
"Sam" <nothn@non.com> wrote in message
news:xXo7e.1008135$6l.180763@pd7tw2no...
: My laptop, Dell Inspiron 1150 2,800 MHZ is now running at it's
maximum
: speed after I rendered a home movie. Previously, my laptop's
performance
: would vary depending on load.
: Does anyone know what has happened?
: Thanks
Reply to Sam
Sneaky, but smart. Too many PC users won't think of changing their
power management settings before rendering something for hours on end
(i.e. don't you hate it when you're watching a DVD and the screen saver
comes on?)
Reply to Anonymous
"Michael Lee" <gte980p@prism.gatech.edu> wrote in message
news:d3mqfd$8vk$2@news-int2.gatech.edu...
Date: Thu, 14 Apr 2005 18:22:46 -0400
saver comes on?)
Why are you using a screen saver with a LCD screen anyway? As they don't
have the burn in problem. Nor does modern CRTs (unless the brightness is
up way too high). Now plasma screens have a real serious problem with
burn in.
Cheers!
___________________________________________
Bill (using a HP AMD 1.2GHZ & Windows 2000)
-- written and edited within Word 2000
Reply to Anonymous
> saver comes on?)
> don't have the burn in problem. Nor does modern CRTs (unless the
> brightness is up way too high). Now plasma screens have a real
> serious problem with burn in.
In addition, why give up _any_ resources to keep a screensaver constantly
running in the background?
James
Reply to Anonymous
Good point. I should turn off screensaver and just use the monitor
turnoff function in its place right? I guess I never thought much about
what affects battery life.. no wonder I never got more than 1.5 hrs of
battery life on my old laptop (I'm spoiled now w/my Centrino chipset).
Reply to Anonymous
Michael Lee wrote:
>> constantly running in the background?
> about what affects battery life.. no wonder I never got more than 1.5
> hrs of battery life on my old laptop (I'm spoiled now w/my Centrino
> chipset).
Yep, just set the display to turn off after whatever period of time you're
comfortable with.
Regards,
James
Reply to Anonymous
I'm sure I've seen TFTs with burn-in.
Duncan.
"BillW50" <BillW50@aol.kom> wrote in message
news:TfC7e.2293$VA3.2094@newssvr30.news.prodigy.com...
saver comes on?)
burn in.
Cheers!
Reply to Anonymous
Hi Duncan... Well I did a Google search through 100 links for "TFT burn
in" and here is what is typically said:
Screen Burn-in: TFT LCD VGA or video monitors do not suffer from screen
burn-in. Although most CRT displays today also avoid this issue, because
of the way TFT LCD monitors are manufactured, there is no risk of burn-
in caused by nonmoving images that are displayed for a long period of
time.
http://www.aeicomp.com/
Although only one forum, someone claimed just as you did. This was at:
http://www.avforums.com/forums/arc [...] 55858.html
Although the last poster admitted that any burn in images doesn't stay
permanent. I've never seen this myself. And I keep the same image on my
TFT displays often for days.
Cheers!
"Duncan J Murray" <duncan.murray@remove.this.bit.medical-
school.and.this.bit.oxford.ac.uk> wrote in message
news:d3tpd1$t0p$1@news.ox.ac.uk...
Date: Sun, 17 Apr 2005 14:47:10 +0100
Duncan.
saver comes on?)
burn in.
Cheers!
Reply to Anonymous
There are 413 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
