Hi
I have a Dell Optiplex 960 Thats Running the following:
XP PRO
E8400 3.00GHZ
4.00 Gigs of ram
Radeon HD 2600 Pro
2 DVD Burners
1 Internal SATA drive
2 USB External Hard drives. (Always Running)
I Currently have a Blueray Player on the way. (to Replace one of the DVD drives)
And I'm planning on investing in a better graphics card
(Not sure which one yet)
Right now the machine is running a 305W Power Supply.
SO..my question is Should I consider upgrading the Power Supply?
If so, does anyone have any suggestions on a Power Supply
My Price limit is $100
It's the biggest Tower Optiplex that dell sells.
I "Think" dell refers to it as a "Mini-Tower"
First time I ever needed to replace a power supply.
Looking at the case I would say it's a ATX.
And feel free to suggest any graphic cards as well.
And you should see the heat sink on this thing! WOW
The machine was free...Figure I should invest some money in it.
Thank you!!!!!!!!
XP PRO
E8400 3.00GHZ
4.00 Gigs of ram
Radeon HD 2600 Pro
2 DVD Burners
Thank you!!!!!!!!
