Hi all,
A few months ago my old AMD64 kicked the bucket. I was impressed by the new SB processor, so I decided to build a new system.
The stuff I bought:
- Intel i5 2500k.
- ASUS P8P67-M PRO
- Kingston HyperX 4 GB DDR3-1333 Kit
KHX1333C7D3K2/4GX, Genesis, XMP
- Zalman CNPS 8000A
- Western Digital WD20EARS
- OCZ ModXStream Pro 600W
- SilverStone SUGO SG02-F
- ASUS EAH4850/HTDI/512M
I've followed the instructionbooklets to the letter, but when I turned my PC on, nothing happened. The videocard cooler turned on and spinned just as the CPU cooler for one second before shutting itself off.
I removed the mobo from the casing, but still nothing. Then removed the hd's, still nothing. Removed the memory and switched it from banks, nothing, took one mem.module out, switched videocards, switched powercakble, switched PSU, used stockcooler, but nothing happens. The only thing that happens is that the CPU coolerfan spins for a second and (if the videocard is connested, that too spins for about a second.) There are no POST indicators on the mobo and it doesn't beep (i have connected an internal speaker) The memory and the videocard are working, since I have tried them on a different system (not a SB system). I also think the mobo does get power, since there are two leds on the mobo that burn ( a green one and a red one).
What could be wrong? Do I have a faulty mobo or a faulty CPU or did I something wrong?
Could someone please give me some advise?
Thanks for the help.
The stuff I bought:
- Intel i5 2500k.
- ASUS P8P67-M PRO
- Zalman CNPS 8000A
