Tom's Hardware > Forum > Digital Camera > Digital Camera General > Repair or replacement of battery door on Canon PowerShot A80
Forum Digital Camera : Digital Camera General - Repair or replacement of battery door on Canon PowerShot A80
Archived from groups: rec.photo.digital (More info?)
A small piece of plastic on battery door of my colleague's Canon PowerShot
A80 is broken and it does not close tightly. I volunteered to figure out
cost of replacing the battery door. I don't have the serial number with me
right now to contact Canon USA email support.
Anybody having experience with Canon USA repair policy? Do they charge a
flat fee, or it is treated case by case?
Replacing the battery door seems not to be that difficult, does Canon sell
the parts only so I can replace the door myself?
Thanks
Sponsored Links
Hi there.
Replacing a battery compartment door is usually very easy, and only takes a
few minutes. If you know what you are doing you do not even need to remove
all the screws from the base, just slacken them off, and perhaps remove the
one or two nearest the hinges. It is unlikely that Canon would supply a
part to a non trade individual. Your nearest repair shop might sell you
one, but would probably charge as much for the part, as they would for
supplying and fitting it. Most of these Doors are cheap, and repairers
often carry stocks, because people snap them off with amazing regularity.
Roy
"Dr. J" <nobody@nowhere.com> wrote in message
news:bP6dnQnnaMd8LJDfRVn-3Q@comcast.com...
> Thanks
Reply to roy
> Thanks
It's just a couple of screw, do it yourself.
http://gallery.bcentral.com/GID202 [...] Cover.aspx
Reply to Anonymous
There are 1156 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
