Solved
Psu related to graphic card problem plzz help..!!!
recently i hav bought a brand new gpu ATI readon 5770hd..!!!! bt its working vry bad..!!! i am not able to play games like cod black ops, fifa 11 and brink..!!! my comp specs are:
dual core 2.8
3 gb ddr2 ram
intel 400w smps...
is the problem is because of smps??? plzzz reply fast...!! thank u..!!
9 answers Last reply Best Answer
More about related graphic card problem plzz help
  1. Are you overclocking the cpu? What is the 12v rail in amps for the power supply? 400w is marginal for your system.
  2. no i am not overcloking my cpu..!!!
    the detail wriiten on my smps is::
    AC Input
    220VAC 4A 50Hz
    DC output
    +5V 40A -5V: 0.5A
    +12V 20A -12V: 0.5A
    +3.3V 28A +5VSB: 2A
  3. is it ok??
    AC Input
    220VAC 4A 50Hz
    DC output
    +5V 40A -5V: 0.5A
    +12V 20A -12V: 0.5A
    +3.3V 28A +5VSB: 2A
  5. I think the problem may have been because of the psu but I can't be sure.The 5770 requires 450w power supply but you have only 400w.Try out this psu.It should solve your problem
    http://cgi.ebay.in/CORSAIR-CX500-POWER-SUPPLY-CMPSU-500CXUK-/120721813929?pt=LH_DefaultDomain_203&hash=item1c1b94b1a9#ht_1281wt_905
  6. Best answer
    For a single Radeon HD 5770 graphics card system the power supply should have a +12 Volt continuous current rating of 22 Amps or greater.
    Your power supply's +12 Volt current rating is 20 Amps which is too low to properly power the system with that graphics card.
    If you can find a Corsair Builder Series CMPSU-430CXV2 it will also provide sufficient power.
    It is not the power supply's wattage specification that you should be focusing on. The most critical specification is the power supply's +12 Volt continuous current rating followed by DC Output quality (i.e. good voltage regulation, low electrical noise and ripple) and then the required number of PCI Express supplementary power connectors.
  7. my budget is jst around 30$ :'( which one shuld i get???
    seeing as you are from India can't you raise your budget to 2439 INR.You will get a high quality psu at that price
  9. Best answer selected by shishir18.
Graphics Cards Components Product
