For a little more power you may want to consider this.
http://www.newegg.com/Product/Prod [...] 6819103846
It has one less core but it is really fast, and has newer technology so you won't need that extra core! Plus if you know a bit about PC's you can unlock this to 4 cores easily! it has L3 cache witch will be great for photo story, and web searching at fast speeds! $90
http://www.newegg.com/Product/Prod [...] 6811119233
This case is very nice looking! it is sturdy, and has awesome airflow, and for 5 dollars more it is worth your time!
That graphics card will play all of your games at 50-70 fps at mid settings so don't sweet it! Plus that graphics card will help your CPU do task faster, and more efficiently thanks to ATI STREAM TECHNOLOGY!
But the choice is up to you...
