Help me with choosing a new card
January 18, 2011 5:45:40 PM
Hi,
I've posted here a while ago but I've managed to get some more money so my budget is now ~300$
I'm changing my gtx260 core-216 to some other, newer card. I'm thinking about:
GTX460 768 (evga SuperOverclocket or gigabyte OC)
GTX460 1024 (a.b.)
5850
6850
6870
Or should I patiently wait for gtx560 release? :)
Rest of my rig:
Q6600 @3Ghz
3Gb Ram DDR2 800
Chieftec 450W (i know it's poor but if I'll have to I'll change it)
More about : choosing card
January 19, 2011 3:02:46 AM
I've got a Q6600 as well. It's at 3.5 and I have the XFX 6870 it runs very nicely able to put my graphics up quite a bit higher while still managing good frames. Definite noticeable improvement over my GTS 250.
a b U Graphics card
January 19, 2011 3:25:18 AM
to me there is only one choice if you are stepping up from a gtx 260................... wait for the gtx 560 it will be the best value imo.
Also Ill give a +1 to getting a new psu which the op will no doubt have to do, instead of running some cheap no name low wattage psu.
January 19, 2011 8:51:46 AM
Ok. I'll wait for gtx560 then and see the prices. If they're to high, I'll go for HD6870 (if it'll be cheaper that is)
a b U Graphics card
January 19, 2011 1:07:33 PM
sounds like a good plan
