I just setup my first build and I'm looking to get a little more airflow in the case. I have a Cooler Masters Storm Scout and looking to add 2 120mm fans to the side panel.
My first question is the fans that came with the case are wired into molex connectors...so is there any way to get them to connect to the mobo for it to control the fan or will they just have to stay at 100% 24/7?
My second question is with adding the two new fans to the side panel will I be able to somehow hook them in with the other 3 fans so that when I press the LED button on the front panel the lights will turn off...I'll be using this in my dorm room and if I'm downloading stuff while I'm sleeping I dont want LED's lighting up my room. So if I can't I'll just use fans w/ no red LED
