Hi all,
Not sure if this is the right board to ask at, feel free to redirect me! This is not my first pc build, I build them quite frequently at work but this one at home is giving me ridiculous amounts of trouble here are the stats:
Gigabyte GA-EP45-UD3P Motherboard (rev. 1.6)
Intel Quad q6600
2 gig G Skill ddr2 ram
2 gig Kingston ddr2 ram
Coolmax CU-700B 700W ATX power supply
NVIDIA 460 GTX
And here are the problems I'm having
1. Power supply: I know the coolmax is not a great one but it's the only power supply I could find with ALL 24 pins, apparently the newer ATX revisions did away with pin 20, the -5v pin, which my mobo apparently needs to work. I also bought a nicer Thermaltake toughpower 750w but this only had 23 pins and wouldn't boot up half the time. Does anyone know of any nicer power supplies that would work? Preferably at least 700 watts...And yes, the psu is set on American voltage...
2. Hard drive, I first bought a pair of OCZ vertex 60g SSDs. I was going to put one in my computer and one in my parents' (which of course works fine). I couldn't get it to show up in either the bios or windows installation screen so I tried it in my parents machine and it didn't show up either. I took out their drive and tried it in mine and it worked fine. Did I just get a bad drive or did my machine somehow kill it?
3. Hard drive 2, after my SSD wouldn't work I put an older Sata 500g HDD in the machine and installed Windows 7 last night. This worked fine until this morning. I went to turn it on and the drive wouldn't spin up. I took it and put it in my other computer and it didn't spin up either. Did it coincidentally die or did something kill it?
4. CD Drive, used a Sata CD drive to install windows on my parents' machine, hooked it up to mine and it suddenly wouldn't turn on. Took it back to parents' machine and it still wouldn't turn on. Coincidence...or murder?
5. CPU temp, reads like 92 celsius, I have the stock fan and a decent amount of thermal paste and good contact here. Not sure if this is some kind of read error or this is contributing to my problem. Earlier when I was trying to get the bios to recognize the SSD, the machine would turn off randomly, presumably from CPU overheating? The rest of the machine is around 30 Celsius and the whole thing is laid out on my wooden table so its getting plenty of air...
So there you have it, either my power supply is killing everything it touches, the mobo is somehow messing things up or I just happen to have 3 components fail independently on the same day...any thoughts?
Intel Quad q6600
NVIDIA 460 GTX
