Sign-in / Sign-up
Will my power supply provide enough stable power for my system?
  • Power Supplies
  • Components
  • Product
Last response: in Components
June 23, 2011 5:46:39 PM
Hey guys,
I am currently finishing up a computer build as follows:
AMD Phenom II X4 955 Deneb 3.2Ghz (http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-)
8GB (2x4GB) Kingston Hyper X DDR3 1600 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-)
ASUS M4A87TD/USB3 w/ 870NB/850SB chipset (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131651&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-)
EVGA GeForce GTX 470 1.2GB GDDR5 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814130616&Tpk=evga gtx 470)
80GB WD IDE HDD
200GB WD SATA 3.0 HDD
Sony CD/DVD R-RW
NZXT M59 Black (http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058&Tpk=nzxt m59)
1 - 140mm case fan
3 - 120mm case fan
Xigmatek HDT-S1283 HS/Fan (http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003)
My plans for this system include overclocking the CPU to 3.5-3.6ghz and overclocking the GPU to 10-15% (depending on whats stable and not too hot)
My question is:
Will the Antec BP550 550W (http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-) be enough to run that system at stock? What about overclocking to my desired settings?
More about : power supply provide stable power system
June 23, 2011 5:48:13 PM
Sorry, I wasnt aware that html was disabled on these forums. I'll edit it quickly and just leave the regular links.
m
l
a c 91 ) Power supply
June 23, 2011 7:19:05 PM
Your build looks fine and yes that PSU will work. I'll recommend a couple of changes though. First, get rid of that IDE drive. And second, change the video card to a GTX 560 Ti. It gives similar performance all the while being less noisy, more cooler and has a lower power draw.
m
l
a c 127 ) Power supply
June 23, 2011 7:21:40 PM
'Yes' to both, but you will not have much headroom for future upgrades and PSU deterioration (aging of caps) over time. Consider 650 Watts or above.
m
l
June 23, 2011 7:35:49 PM
The GPU was actually a gift, typically I would buy Radeon's for myself but Im not gonna turn down a free GTX470 ^^
Thanks for the responses guys, much appreciated.
Side note - This PSU, despite being only a 550W rated has a 12V rail total of 69A. Seems kind of insane the difference between the two..
m
l
June 23, 2011 7:40:23 PM
"Never look a gift horse in the mouth!" :)
m
l
