Looking to buy a new system, but with the gpus, etc, is 800w enough?
HELP!!!
Case: * CoolerMaster 690 II Advanced Mid-Tower Gaming Case [+17] (Black Color)
Internal USB Extension Module: None
Neon Light Upgrade: None
Extra Case Fan Upgrade: Default case fans
Noise Reduction Technology: None
CPU: Intel® Core™ i7-2600K 3.40 GHz 8M Intel Smart Cache LGA1155 (All Venom OC Certified) [+110]
Freebies: None
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Motherboard: * [CrossFireX] GigaByte GA-P67A-UD3-B3 Intel P67 Chipset DDR3 ATX Mainboard w/ 7.1 HD Audio, GbLAN, USB3.0, 2x SATA-III RAID, 2 Gen2 PCIe, 3 PCIe X1 & 2 PCI [B3 Stepping]
Motherboard Expansion Card: None
Memory: 8GB (2GBx4) DDR3/1600MHz Dual Channel Memory Module (Corsair or Major Brand)
Freebies: None
Video Card: AMD Radeon HD 6990 4GB GDDR5 16X PCIe Video Card [+724] (Major Brand Powered by AMD)
Video Card 2: AMD Radeon HD 6970 2GB GDDR5 16X PCIe Video Card [+423] (Major Brand Powered by AMD)
Video Card 3: None
Dedicated PHYSX Card: None
Multiple Video Card Settings: Xtreme Performance in SLI/CrossFireX Gaming Mode Supports Single Monitor
Power Supply Upgrade: 850 Watts - Raidmax RX-850AE 80 Plus Gold Power Supply
Hard Drive: 1TB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD (Single Hard Drive)
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
LCD Monitor: 24" Widescreen 1920x1080 Sceptre X246W-1080P LCD (Viewable 23.6")(Black Color) w/ Built-in Speaker, DVI & Input [+159]
2nd Monitor: None
3rd Monitor: None
Speakers: None
Network: Onboard Gigabit LAN Network
Network Switch: None
Keyboard: * Thermaltake eSports Challenger Pro Gaming Keyboard Black [+53]
Mouse: XtremeGear Optical USB 3 Buttons Gaming Mouse
Mouse Pad: Razer Goliathus Fragged Omega Mouse Pad - Speed [+13]
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: Zonet ZEW1642D IEEE 802.11b/g/n 300 Mbps Wireless Card + External 2.4G 7 Dbi Omni-Directional Wireless Antenna [+39]
HELP!!!
Freebies: None
Freebies: None
Video Card 3: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Gaming Gear: None
