Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > [Solved] TV Tuner Card Stops My Internet, Help!!!
Forum CPU & Components : Other Components [Solved] TV Tuner Card Stops My Internet, Help!!!
Best answer from Leaps-from-Shadows.
I just bought an AMD Theater HD 750 TV Tuner PCIe Card for my PC. When I install the drivers my wired internet stops being able to connect. And when i try to run the troubleshooting diagnostics it gets to resolving problems, then my computer freezes. I did system restore and it was working again, went through the same steps and got the same problem? Any ideas. The tuner card is supposed to work with my PC. Thanks for any help! :)
------------------------------ http://valid.canardpc.com/cache/banner/1842598.png
Reply to kr0490
Can you try the tuner card in a different PCIe slot? It sounds like some sort of resource conflict. Also, try looking for an updated driver on the internet if you haven't already.
------------------------------ Jack-Booted Thug Spreading Intel Sandy Bridge Propaganda
Member of the Official TH Water Cooling Club
|2500K CPU|12GB RAM|570 GPU|96GB SSD|1TB HDD|
Reply to Leaps-from-Shadows
i only have one 1 lane pcie slot, can i put the 1 lane card in a 16 lane pcie slot?
Reply to kr0490
Yeah, go ahead and try it in the gray PCIe slot ... it should work there too.
i switched it to the other slot, now internet works, but it has an exclamation point by it in device manager and says something like cannot start, code 10, and if i right click in device manager and scan for hardware changes, it disappears completely from the list. And i have the latest drivers.
Message edited by kr0490 on 06-24-2011 at 03:41:49 AM
Reply to kr0490
Best answer
Okay ... you have two PCIe slots that the tuner card can be plugged into.
If you plug it into slot A, the network port stops working.
If you plug it into slot B, it isn't detected by Windows.
Sounds like the slots share resources with other stuff on the board.
Will Windows detect the tuner card (in the gray slot) after a reboot or a cold boot? If not, then it's likely not compatible with your board.
Edit: If another user got it to work on the same board, then you'll have to ask them exactly how they did it.
Message edited by Leaps-from-Shadows on 06-24-2011 at 03:57:24 AM
put it back in pcie 1 lane slot, is instantly recognized again, and internet is disabled again.
Reply to kr0490
My motherboard manual says something about after installing an expansion card slot, changing necessary settings in the bios, and assigning an IRQ to the card. It also says something about when using PCI cards on shared slots, ensure that the drivers support "share IRQ" or that the cards do not need IRQ assignments. Otherwise, conflicts will arise between the two PCI groups, making the system unstable and the card inoperable.
Does this pertain to my problem, because it does talk about possilbe confilcts occuring. If so, what do i need to do?
here is a picture of an IRQ chart in my manual if needed
http://i208.photobucket.com/albums/bb178/kr0490/IMG_0136.jpg
Thanks! :)
P.S. Sry for sideways and LQ picture, took with my phone
Message edited by kr0490 on 06-24-2011 at 04:29:32 AM
Reply to kr0490
It's entirely possible that the tuner card's drivers don't support IRQ/resource sharing. I don't think there's anything you can do to fix/change it.
Im returning my card to micro center and am instead going to get the USB version of the tuner, has all the same functionality, with none of the hassle (or at least i hope not). Thanks for the input and help! :)
Reply to kr0490
Best answer selected by kr0490.
Reply to kr0490
There are 1635 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
