Sign-in / Sign-up
UATX Case N' Cooler Question
  • Power Supplies
  • Cases
  • Components
Last response: in Components
June 25, 2011 12:16:34 AM
Hi
I am building a new mini ATX rig that will use sandybridge
The following is the specs:
CPU : Core i5 2500k (OC to 4.5ghz)
Mobo : Asus ROG Maximus IV Gene-Z
RAM : 1866mhz CL9 8gb corsair vengeance
GPU : EVGA gtx 570 sc
There will be one 1tb hdd, and one optical drive.
So the question is,
I have corsair H50 ready to be installed for my oc'ed i5, but I need a case that I would be able to mount 120mm fan as well as house my long gtx 570.
Or should I buy a new non-water cooling solution, and what would you recommend?
Also, what would be the case I should get if:
1) I get H50 cooler, or
2) Heatsink Solution
And my last question is:
Are HT (Home Theater Cases) good for my GTX 570?
I was thinking about getting Antec P180 mini but I'd prefer something lighter for mobility
Thanks
More about : uatx case cooler question
a c 132 ) Power supply
June 25, 2011 1:59:02 AM
Most HT cases wont fit any full height full length cards as hey are for low power builds, not gamer.
But now that I think about it, some of the cube style ones, like the thermaltake lanbox, might but then you run might run into PSU issues.
m
l
