I've been lurking and I've got my own newegg wishlist working, but I'm wondering about the CPU cooler that comes with the i7 & i5 K chips.
My current plan is to try the integrated graphics, as I don't play games, and the computer is in the bedroom, so I don't want an obnoxious fan running. I'm going to probably use a mATX H67 board <- no overclocking. The CM 212 is my choice for an aftermarket cooler, primarily for cost and noise, but if the stock cooler isn't loud, then I might just drop it from the list. I've eyeballed the Fractal Design Define R3 for a case, but might reuse my current full tower case (another post later on).
I can't seem to find any reviews where they comment on the noise of the stock cooler; If I overlooked one, a link would be appreciated.
Thanks for looking
Thanks for looking
