I have a 5830, attempting to set up eyefinity across 3 monitors. Two are hooked up with DVI to VGA adapters. The third is through my displayport. I had to purchase the Active displayport adapter, but I got the Accell Active Displayport adapter to DVI-D; I have this running into a DVI-D to DVI-I adapter, and then into a DVI-I to VGA adapter for my third monitor.
I cannot get the third monitor to work. Windows 7 and CCC recognize it, but will still only display the two DVI-VGA monitors. What's wrong?
Does the DVI-D to DVI-I adapter kill the active link? Or is it something else? I've followed Sapphire's instructions closely on how to run eyefinity. I've also looked everywhere for a solution. Thanks in advance.
